Holley Stealth Ram-FI parts galore-plus a few other things
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Said screw it and I am putting a carb on this sucka.... All this stuff only has a little over 6,000 miles on it. If anybody wants more then one thing or several things Ill make ya a deal on it. Buy pays shipping.
B&M 24,000 gvw trans cooler. $40
8 Ls1 injectors-all in good working order $80
Map sensor with pigtail $15
Aeromotive fuel pressure regulator #13105 with -6 AN fittings on it 30-70 psi $140
MSD blaster coil for late GM $30
Car: 1988 Formula
Engine: 355
Re: Holley Stealth Ram-FI parts galore-plus a few other things
MSD Pro billet distributor for TPI car #8366 One of the connectors is cracked a little but doesnt effect the plug and it stays plugged in just fine. Also the wheel and pickup have some surface rust on them. It still works perfectly fine, I have had zero problems what so ever from it. For some reason it just have surface rust on it. $200
730 ECM with two burnable proms and a Moates piggy back quick change thingy? $50
Homemade CAI for SD car. 3 inch tubing with nice silicone connectors, a K&N cone filter and all the clamps $80
BBK 58mm throttle body for TPI car All sensors and bolts included, all functioning fine. $250
Car: 1988 Formula
Engine: 355
Holley Stealth Ram intake. Fuel rails included with a summit pressure gauge. Intake is in great shape. I polished the upper ribs and it has been painted with high temp aluminum color paint. Only flaw is on upper left corner it rubbed on my hood a bit. $450
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
I'll take it
I'll take it
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Is that CAI for a camaro? would it work without relocating the batterey?
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
how much would shipping be to missouri at 63361
Car: 1988 Formula
Engine: 355
The CAI would work either way. You could flip it and make it go drivers side of passenger side.
I may be using the braided lines I have on my carb. Dont know yet, if I decides to sell em Ill let ya know.
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
would your LS1 injectors fit my 86 T/A... typical 305 TPI? what rating are they... 19 lb/hr? I'm interested... I think my 22 year old injectors are holding me back! Also interested in pressure regulator... thanks!
Car: 1988 Formula
Engine: 355
LS1 injectors are 28# They will fit and work just fine, but you will need some tunning to compensate for them.
Car: 1986 Trans Am
Meatman... thank you... that is what I've learned today, that I should probably just stick with 19 pounders. Mine is a daily driver and I'm not into tuning... but I wish I was!
Car: 1988 Formula
Engine: 355
Bump.....stuff will prob go on ebay soon if it doesnt sell here.
Car: '92 Z28 25th anniversary/ '89 RS
Engine: 400 sbc
Axle/Gears: moser 12 bolt w/4.10
what is still for sale? pm me please, i would be very interested.
Car: 1988 Formula
Engine: 355
Bump.....Everything that still has a picture I still have. Make me some offers.
9192camaro
16
02-03-2019 12:21 AM
86IROC112
08-17-2015 02:00 PM
