extreme automatics built 200r4 trans and converter
Car: 91 ta
I have for sale a bfr 200r4 built by Lonnie Diers of Extreme Automatics and a 3000-3400 stall Bradco converter.The trans was built a few years ago for a tsm car but never made it yet, so the best of the best was used. here is a list.
a.. Billet Forward Drum
a.. Treated Input Shaft
a.. EA Billet 2nd Gear Servo
a.. 8 Clutch Direct
a.. 5 Clutch Forward
a.. Metallic Hi Energy Clutches
a.. Dual Feed 3rd Clutch Apply
a.. Hi Performance Calibrated Valve Body
a.. .400 Reverse Boost Valve
a.. All bushing are replaced
a.. All Torrington bearings are replaced
a.. All thrust washers are replaced
a.. All seals and gaskets are replaced
a.. Harden stator installed in every unit
a.. Alto super Band installed in every unit
a.. Billet anchor pin installed in every unit
a.. New Pump assembly
a.. EA Hi Pressure regulator valve and spring
a.. EA Hi RPM pump priming spring
a.. Billet pump rings
a.. Pump drains drilled
a.. Pump bushing staked
a.. Tensioned Teflon sealing rings are used
a.. 3 clutch OD
a.. Billet Aluminum Direct Apply Ring
a.. Tested and sealed center support
a.. Electric transbrake
a.. Sheet alum pan with bottom mount sump
a.. Heat treated input shaft
a.. heat treated OD ring gear
This is a nonlockup trans and has been in my gn for a couple thousand miles. Before this trans and converter is shipped out, i will send it back to lonnie to be gone through and freshned up.I am asking 3200.00 shipped for the trans and converter.Paypal add 3%. Thanks Tom Robison
a.. 8 Clutch Direct
a.. 3 clutch OD
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
08-09-2015 04:32 PM
1992 Trans Am
08-08-2015 08:16 PM
