Coan 10in 3500 stall converter for th-350, th-400
I've changed my combination and bought a new converter to match. This converter worked great and never gave me any problems. Its Coan part # COA-20315 competition series furnaced brazed 10in converter for th-350 or th-400. I'm asking $200 for it. If interested in please send me a pm or email me at camarof41_383@yahoo.com
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
Re: Coan 10in 3500 stall converter for th-350, th-400
would it work with a trans break and is it a small bolt pattern. also does it have a ext on the hub so i can run a 1/4 spacer so it still engages the crank. thanks
Heres a pic showing the hub that should answer that question. It has the standard bolt pattern for a th-350 . It should work with a transbrake, I would call or email Coan's tech support to see if they would recommend using this converter with a transbrake in your application.
Hotrodboba400
12-10-2019 07:07 PM
MikkoV
09-09-2015 04:25 PM
