Turbo goodies: RFL TIAL 44 13202 reg BBT76 .96 AR
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Ive decided to go all motor instead of building the turbo set up
Real Turbo XS RFL, slightly used, comes with 1 aluminum weld on bung. Some of the chrome is chipped off on the horn. Also comes with adjusting washers to increase holding pressure, good to 25PSI $80 shipped
Real (S/N is etched on top) TIAL 44MM wastegate. Im unsure what spring it will come with, either a 6 or 8lb spring. Wastegate flanges are not included as this is off of a friends current turbo set up that was used for 800 miles. Worked awesome, controlled with no creep at 3lbs on a 355 and T76 GTS, all the way up to 18lbs with the same 3lb spring. Titan motorsports stocks the flanges for 15bucks each for mild steel, or you can find the SS anywhere for 25 each. $275 shipped on the wastegate, PM for spring details
Aeromotive 13202 boost referenced fuel pressure regulator, this is NEW still in the box with instructions. Alot of the big turbo guys over on Turbomustangs is usuing this from 11sec cars to 8sec cars. Its a monster of a regulator. $145 shipped.
I also have a used BB turbonetics T4 .96 T76 that has about 6,000 miles on it, no end to end shaft play, some up and down when the turbo has not been ran in a while due to the ball bearing, after being ran, there is no up and down shaft play. This turbo on my buddies car with a 4k stall would make 2-3lbs of boost at 1/3 throttle at 2800 RPMs, that was a STOCk head/cam 355 LT1. Car went 10.80's @ 128 on 8lbs in first gear, and 11 in 2nd/3rd. Asking $1,000 for it.
I also have a Mild steel 1/2" T4 flange with a coper gasket and steel shim gasket $20 shipped
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Re: Turbo goodies: RFL TIAL 44 13202 reg BBT76 .96 AR
Wastegate flanges are in the mail, and should be here by COBD Wednesday.
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Wastegate is sold.
Pending sale on Turbo.
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Pics of the turbo
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
TTT
Last chance for the regulator.
Turbo is still up forsale
BOV is still up for sale
T4 flange and gaskets are still available.
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Regulator is gone
Turbo - new price $975 shipped
I will aslo consider trades, looking for:
~4000 stall for Th350
Tubular Kmember for SBC
Hooker 2210 LT's
Mallory 685 ignition box.
Hooker 2210 LT's
