Aluminum L98 heads from my 91 Corvette FS
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
I bought some Trick Flow heads for my Corvette, so my stockers are for sale. They are bone stock aluminum heads from a 91 Corvette. 61,000 miles on them. 58 CC combustion chamber.
Stock valve springs, or for another $50 I'll put some LT4 springs on them.
$400 for the set, or $450 with the spring upgrade.
I also have the stock cam and lifters if anyone is interested.
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
Re: Aluminum L98 heads from my 91 Corvette FS
part # please..Have family in louisburg that can pick up.
Car: 1991 Corvette
I've always just heard them referred to as '113' cylinder heads. After a bit of research, and looking at the heads, here's what I have found:
Casting number is 10088113.
The heads are available complete from GM under GM part number 12556463. Here's the description from GMPP:
Part#: 12556463
Desc: Corvette Design for 350 HO service engine
Casting: 10088113
Material: Aluminum
Intake Runner Volume (cc): 163
Combustion Chamber Volume (cc): 58
Valve Diameter: I: 1.94" E: 1.50" D" port exhaust
Spark Plugs: Angled
Heater riders: No
This aluminum cylinder head assembly for small-block Chevrolet V8s is ideal for street rods, fresh-water power boats, and high-performance applications. GM Performance Parts' aluminum cylinder head assembly combines the benefits of light weight, advanced design, and an affordable price.
This complete head assembly includes valves, chrome silicon heavy-duty valve springs, retainers, 3/8" screw-in rocker studs-everything an enthusiast wants in a high-performance cylinder head package! GM Performance Parts aluminum cylinder head assemblies are based on brand new Corvette light alloy castings (P/N 10088113).
The Corvette cylinder head's advanced design features include D-shaped exhaust ports that enhance the flow of burned gases, high-velocity intake runners that provide crisp throttle response, and centrally located spark plugs that improve combustion efficiency. Valve seat inserts for 1.94" diameter intake valves and 1.50" exhausts are installed in the 58cc combustion chambers.
Raised rocker cover rails with machined sealing surfaces virtually eliminate rocker cover gasket oil leaks. This high-performance cylinder head assembly is used exclusively on High Output 5.7-liter small-block V8 engines. Unlike production Corvette cylinder heads, it is outfitted with special heavy-duty valve springs (see part number 12551483 for technical specifications).
A pair of aluminum cylinder heads offers a weight savings of approximately 50 pounds over comparable cast iron cylinder heads. (A bare aluminum casting, less valves and springs, weighs 19 pounds, versus 44 pounds for a bare cast iron head). This reduction in total engine weight of 25 pounds each can improve handling, acceleration, and fuel economy.
Part Number...Description
12555269.........Stamped steel rocker cover
10229162.........Corvette screw-in oil filter cap
12342056.........Chrome screw-in oil cap w/GM logo
12338092.........Valve cover hold-down bolts (8 required)
14094717.........Hold-down bolt washers (8 required)
14088793.........Hold-down bolt gaskets (8 required)
14088564.........Neoprene rocker cover gasket
12557236.........Composition head gasket, .051" thick
12495499.........Head Bolt Kit
12495490.........Rocker Arm Kit
Technical Notes: This casting does not have intake manifold heat riser or EGR passages. The spark plug holes are angled; check for adequate exhaust manifold or header clearance. Use 3/4" reach gasketed spark plugs with 5/8" hex heads (AC FR5LS), 904, or MR 43LTS. In rapid fire use #8 plug. Both ends of the head are machined for alternator, power steering, and air conditioning compressor mounts. No pushrod guideplates; use rail type rocker arms P/N 10089648. This aluminum head assembly requires valve covers with central hold-down bolts and extra-long bolts with washers. A composition head gasket with stainless steel fire rings is recommended to prevent galvanic action between the head and a cast iron engine block. This head assembly is the same as P/N 10185087, except valve spring and retainer change.
The only thing I noticed is that I'll include the factory guide plates, unlike the new GM heads.
Part#: 12556463
Casting: 10088113
Material: Aluminum
Spark Plugs: Angled
Heater riders: No
Car: 1991 Corvette
I guess I could mention my track times. I'm not sure, but I think my car is/was the fastest car out there that was still using the bone stock TPI intake and no power adder.
On motor, I went 12.84 @ 106. As far as I know, that's the fastest NA, un-modified TPI intake car there is.
On a 100 shot I went 11.99 @ 112. I'm pretty sure the power adder record (for an unmodified TPI intake car) is 11.77. I think I might have been able to go faster than that on a 150 shot, but I never tried it.
I guess my point is that heads work pretty well for what they are.
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
pm sent
Car: 1991 Corvette
All PM's are responded to.
Car: 1991 Corvette
Thanks for the interest, heads are sold.
Car: 1991 Corvette
I really don't have any idea what a fair price is. $75?
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I've been looking around and generally I see them priced from $25-$45. I saw ones priced higher, but other parts were included (ie. pushrods, rockers, the hold down piece, etc.).
Rich
Rich
Car: 1991 Corvette
What all do you need? I have everything from the cam to the heads.
ambainb
04-25-2016 09:21 PM
