Everything to swap a T5
I have everything to swap an automatic car into a 5spd car, T5 borgwarner, V8 bellhousing, new clutch and pressure plate, flywheel 4 a 1 piece RMS, new slave cylinder, master cylinder, resevior, pedals, shifter, shift plate and boots, cross member, everthing is there to do it, i'll take 500 for all of it, pick up only no shipping, i live in Ky.
Re: Everything to swap a T5
Hello, Do you still have T5 and other parts? Was T5 orignal V8? Is there an ID tag with numbers? Is T5 electric or mechanical speed0? World class or no? Thanks, TurboTim59
Car: 91 Rs
Engine: 383 hydrolic roller carb
Just to let you know those numbers wont get you any information on that trans....There is a metal tag bolted to the trans that has numbers stamped on it or there is a sticker on the top of The trans near the front that has the numbers on it. they start with 1352 and followed be three numbers. These numbers will help you find out the year and other info on the trans. I just bought a setup for mine and had to fund out this info so I help that helps with this ad
sorry guys i havent checked this in a while, it has the manual speedo, heres the number 13-52-065-914, idk what world class means or i would answer that, its a 26 spline input, so it aint out of an S10 or anything. anymore questions??
Hello Critter2655, Do you still have trans?? What are the tag numbers from the tag located on the top of the trans near the front? The tag will have a bar code on it as well. More than likely covered in grease. Can you post a close up pic of the front of the trans? Does the trans use gear oil or ATF?? Do you know what year and car it was removed from?? Sorry to ask so many questions but I am in upstate NY and don't want to make a trip for the wrong parts. Thanks, TurboTim59
065, 097, 1352, 1352065, 1352065914, 1352097917, 914, 917, borg, numbers, s10, t5, tag, transmission, warner
