87-92 F body Serpentine Setup. ASP Crank Pulley and GM Delete Pulleys
Old 03-02-2008 | 12:45 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
GM 87-92 F-Body Serpentine Setup-Includes 105 Amp Alternator, PS pump, Brackets, Tensioner, new GM GM Smog Delete Pulley, Water Pump Pulley, and USP Underdrive Pulley. Used $200 Shipped FIRM. Add 3% for paypal.
Old 03-03-2008 | 09:51 PM
drain89's Avatar
Re: 87-92 F body Serpentine Setup. ASP Crank Pulley and GM Delete Pulleys
bump
Old 03-03-2008 | 10:40 PM
peepsrs's Avatar
Car: 91 Rs
Engine: 383 hydrolic roller carb
Will you sell the smog delete seperately...I will send you back a smog pump w/ a pulley on it to include with your package I want the delete.
Old 03-03-2008 | 11:18 PM
drain89's Avatar
let me see what i got in it. i'll get back to you.
Old 03-04-2008 | 10:33 AM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
PM sent
Old 03-05-2008 | 12:35 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
let me know if you'll sell the ac delete pulley seperate also.
also if the pump is for sale and if so ammount of use on it. pm me if u will quite interested.
Old 03-06-2008 | 06:39 PM
drain89's Avatar
bump
Old 03-07-2008 | 08:15 AM
fastregalwe2's Avatar
is all this still available?
Old 03-08-2008 | 02:40 PM
drain89's Avatar
yes.
Old 03-09-2008 | 12:49 AM
drain89's Avatar
bump
Old 03-09-2008 | 08:52 PM
slim64's Avatar
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
Im interested in the entire setup, i just had a couple questions though,
Does the setup include the water pump? (its in the pic, but not on your list)
Are all the bolts included to bolt this setup up to a motor?
Approx how many miles are on this setup?
This should bolt up to any genI small block right?
Thanks in advance,
-richard
Old 03-09-2008 | 10:20 PM
drain89's Avatar
edit...see below
Old 03-09-2008 | 10:31 PM
drain89's Avatar
No the water pump was sold serperately. It's long gone.
Most of the bolts were thrown away when I removed it. But I do have some. I was gonna replace them with new stainless button head fasteners. Depending on what year block you're using you'll need to check if it uses standard or metric accessory bolts. If you're using old school heads you may have to drill and tap the accessory bolt holes.
I have no idea how many miles it has, It come on an 86 Iroc I bought and stripped for parts. Being an 86 the serpentine wasn't original to it since they didn't put them in camaro's until 88. Everything worked fine before removed.
Old 03-10-2008 | 07:04 PM
drain89's Avatar
bump
evilstuie
01-09-2020 09:29 PM
evilstuie
04-14-2016 09:52 PM
BlackphantomZ28
08-21-2015 08:12 PM
actionj
Carburetors
08-16-2015 10:51 AM
Street Lethal
08-12-2015 12:33 PM
