Dakota Digital Speedometer calibration box
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Used for recalibrating your swap on a third gen or anything else where you need to make your speedometer read accurate because of a tire size change, or going to a six speed where the VSS is a differant output than what your car originally had. I dont think this will work on an LS swap because I believe that is controlled through your ECU. I think they go for 80-100, I am not sure. Will let it go for 25 bucks shipped.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Dakota Digital Speedometer calibration box
Number 3, please.
Car: 91 Rs
Engine: 383 hydrolic roller carb
I am the purchaser of the one on this post....I thought it was going to come with a manual or somehting...does anyone know how to use this to calibrate the spedo? pm me please or write me at brandoncatena@hotmail.com
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
If you go to the website below, look up your model number and revision and download the correct PDF for your model.
http://www.dakotadigital.com/index.c...rod/prd393.htm
You will also want to do a few searches on this site, as I remember many people complaining that their instructions that came with the box were 100% wrong.
gixxer92
04-12-2022 12:09 AM
