010 High Nickel 4 BOLT Block Waco Texas
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Im selling my 010 High Nickel Block, its casting number is 3970010 its a 4 bolt main block. Check mortec.com same casting numbers as the 302 blocks if perhaps u want to make a clone but its standard 4.000 bore from my measurements, i got it in a trade from my buddy a while back and was going to build it eventually but just got a new motor and need some other parts for it so need some cash... This block should be a good strong one for a stout build. asking $300 OBO also have a set of heads casting numbers 462624 asking $50 for them. but will throw them in with the block if willing to pay the 300... in Waco texas
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: 010 High Nickel 4 BOLT Block Waco Texas
will take 200, need to get out of my garage and need to get my new cam and carb to have my 86 goin again
Car: 1990 Firebird
Engine: 600 hp 353.4 CI
Transmission: TH-350/B&M3000
Axle/Gears: 10 bolt 3.23
i'd take it if you werent so far. you can never have to many of those blocks.
evilstuie
01-09-2020 08:29 PM
