Edelbrock 1411 750cfm E choke $150
Old 01-24-2008 | 01:54 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I have a used 1411 750 edelbrock carb. It will also come with the calibration kit/book. This carb works great when you want an easy starting car, and will feed a decent bit of power.
Its currently too small for my engines needs, but worked great when i had a 350, same heads, and flat tappet cam. Car usually starts as soon as the starter is engauged and will run great.
Carb has been rebuilt about 100 miles ago with all new gaskets/seals and currently sports the largest jetting you can stick in it with the calibration kit, let me know what jetting you want it to come with, and i will go ahead and change it for you.
Old 01-28-2008 | 09:37 AM
Car: 87 Firebird
Engine: 5.3 76mm
Re: Edelbrock 1411 750cfm E choke $150
bump
no green
01-09-2016 10:22 PM
armybyrd
Carburetors
10-20-2015 04:57 AM
darwinprice
17
10-12-2015 12:51 AM
efiguy
09-27-2015 02:30 PM
Night rider327
09-25-2015 05:47 AM
Quick Reply: Edelbrock 1411 750cfm E choke $150
