Richmond 3.42 "Thick Gear" for 2 series
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Selling Richmond 3.42 ratio Gearset for 10 bolt, 7.5/7.625 rear. This is the "Thick" gear for 2 series posi carrier.....If you have 2.41, 2.73 or 3.08 gears in your axle now, you can swap these thick gears right into your rear without having to change the posi to 3 series carrier...This set is used but in excellent condition. $100 shipped anywhere in the lower 48 states.....I also have 3.42 gearset for 3 series carrier if thats what you need, and 3.23 as well.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Re: Richmond 3.42 "Thick Gear" for 2 series
have you got 3:73's for 3 series?
codeysabatini
11-10-2015 04:07 PM
georgiaslim45
09-09-2015 08:11 PM
UltRoadWarrior9
09-02-2015 08:24 PM
