Paxton L98 Injector Plate with HKS Injector Controller Controller
Car: Purple Haze Metallic 92RS
Engine: Super-ram 383cid
Transmission: race prep 700R4
Paxton L98 Injector Plate with HKS Injector Controller For Turbo or Supercharger
Since the time has come to finally sell my beloved third gen I though that I would try to sell a few of the non-essentials separately. I am offering for sale a used Paxton supplemental injector mounting plate and HKS control unit. This plate mounts in between the throttle body and the plenum. It houses 3 standard Bosch style injectors and uses emulsion tubes to spray the addition fuel into the engine (much like a nitrous plate.) The plate includes 3 injectors of unknown flow rate. I have not tested these particular injectors but they appear to be in fine serviceable condition.The supplemental injector adapter was purchased from Paradise Wheels around 3 or 4 years ago. This piece has been discontinued for some time.
Normally the supplemental injector system from Paxton would have included the Paxton "Paxta-Map" fueler, a basic but functional unit. I however substituted a very nice additional injector controller from HKS Japan. The third generation HKS AIC unit is completely user programmable, so you can set your own fuel enrichment curves based off of boost and RPM. I am selling everything needed for this system to function (save for fuel lines to the injector plate.) You will receive everything pictured and also the instruction manual (which is not in the attached pictures.) Injector plate, HKS AIC head unit, main harness, power amplifier (to drive the injectors) vac/press sensor, and injector harness (note that if one were to want to drive more than 3 additional injectors a new harness would need to be purchased but the HKS AIC can control up to eight additional injectors.) The HKS AIC is fully tested and 100% working when removed from my Camaro last week. The head unit has some orange stuff on the top that looks liek what was used to mount it in a vehicle at some point, but there are no scratches on the display itself, and all of the buttons work.
All in all a very nice setup for turbocharged or supercharged cars where you may not want to run a large primary injector. This allows you to run reasonably streetable injectors but still have plenty of fuel when making boost. I have invested over 625.00 dollars into this setup. I would like to see 400.00 or a reasonable offer.
Please feel free to email or PM me if you have questions or would like additional photos.
Thanks!
-Mike
Complete Kit
Injector Plate close up
Head Unit close up
Head Unit Functions
Thanks!
-Mike
Complete Kit
Head Unit close up
Head Unit Functions
Re: Paxton L98 Injector Plate with HKS Injector Controller For Turbo or Supercharger
*Bump
*Bump
*Morning Bump
*Bump
*To the Top!
Nobody with a turbo or supercharger is looking for something like this? I am willing to consider all reasonable offers. Also I am willing to break up the injector plate from the AIC controller.
-Just Make an Offer-
toronto formula
11-10-2015 06:17 AM
3rd, additional, aic, aic1, control, controller, fuel, generation, hks, injector, lt1, manual, paxta, paxtamap, paxton
