19lb/hr Ford Yellow Top Injectors
Old 11-09-2007 | 08:37 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Set of 8 with around 30,000 miles on them. I haven't run them, but they ohm just fine. IIRC, I was told that ford rates them at a lower psi, so at 45psi they are more like 22lbs/hr. $50 plus shipping
Old 11-10-2007 | 08:18 PM
jokestyle90's Avatar
Re: 19lb/hr Ford Yellow Top Injectors
WILL THESE FIT MY 90 FORMULA AND DO THEY ALL WORK
Old 11-10-2007 | 08:34 PM
Engine: that I like
If you have tpi, yes they will fit (same dimensions as stock). I have not personally run them, they came from a running junkyard motor that was sold to the shop I work at. We installed the motor into a customer's truck and reused the original injectors. All eight ohm out fine and have around 30K on them.
Old 11-18-2007 | 11:28 AM
Engine: that I like
bump
Street Lethal
04-30-2019 01:14 PM
Steve78LT
02-24-2016 01:15 AM
InfinityShade
08-22-2015 09:00 PM
ZsTransAm
08-11-2015 08:30 PM
