700R4 & 355 block MEMPHIS, TN
Car: 99 TA---94 toyota p.u.
Engine: LS1----22re
Transmission: T56----5speed
Axle/Gears: 4.10
I have a 700R4 auto transmission out of a 92 GTA, car ran when i parted it out. (front end collision) Asking $100 pick up in memphis TN, trans is out of car.
Also have the 350 engine out of that 92 GTA. I planned on putting that 350 TPI in my 88 iroc. But changed my mind. I have the motor torn apart, had the blocked cleaned, tested, and bored. So it would technically be a 355, but you could do a 383 if you wanted. I have all the stock rods, pistons, crank, but i would recommend just getting a rebuild kit.
I DO NOT have the TPI set up, (manifold, rails, injectors, TB, etc)
Asking $100 for the block (comes w/ heads, pistons,rods,crank)
lt195z@yahoo.com
lt195z@yahoo.com
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
Re: 700R4 & 355 block MEMPHIS, TN
I am also interested in the block I will be in the area the weekend of Nov 9-11
Hotrodboba400
12-10-2019 07:07 PM
RyanJB
09-14-2015 03:39 PM
Bob88GTA
09-10-2015 09:07 PM
