Complete LT1 Intake Conversion
Car: 89 Iroc-Z
I will be pulling my LT1 intake off either today or tomorrow. It is a complete setup. Only thing you will need to buy are intake gaskets and I would get new intake bolts w/ washers. It includes:
-LT1 Intake
-Fuel Rails
-19lb Fuel Injectors
-Fuel Lines
-Accel Adjustable Fuel Pressure Regulator
-Distributor Clamp
-Remote Thermostat Holder
-All Coolant Hoses and Clamps
-All Vaccum Lines
-52MM BBK Throttle Body (w/ new TPS)
-Corvette Covers
-Maybe an LT1 cam w/ dowel already cut if you really would like it.
This is a great system to put on an L98 motor. The combo of the intake and cam made impressive power. You will lose some torque, but gain a good amount of power. This setup is alot easier to work with then the TPI setup. I would like to get $600 for everything. There is a small pic in my avatar, but I will post better pics later today or tomorrow.
-LT1 Intake
-Fuel Rails
-Fuel Lines
-Distributor Clamp
-All Vaccum Lines
-Corvette Covers
Car: 89 Iroc-Z
Re: Complete LT1 Intake Conversion
Heres a pic of it still on my motor. I'm pulling the motor out tomorrow and then the intake. So I will take pics of all the parts.
Car: 1976 Corvette Stingray
Engine: LB9 TPI- Want to go bigger!
Transmission: TH700R4
Axle/Gears: 3.08
stupid question but does an existing LB9 or L98 harness and ECM work with this?
Car: 89 Iroc-Z
Stingry - Both those harnesses work, but I would only suggest using this intake on an L98 I heard it does nothing with a 305 unless you put money into heads and a cam.
Dave - I live 45 mins north of Philly in a town called Lansdale.
I'm just outside of Quakertown.
If you want to PM me your info, I would love to come see the setup and possibly buy it.
Let me know. Hopefully we can work something out!
Terrell351
06-13-2021 01:13 PM
1992 Trans Am
08-08-2015 08:16 PM
