Pro topline heads - aluminum
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Pro topline heads f/s
2.02/1.60 valves 200 runners 64cc with angle plugs
Brand new, never installed/ported or modified in any way
Requires 11/32 valves with +.100" stem length
Im throwing in 2 sets of forged pushrods that are +.100" length
Uses a Felpro 1206 gasket
Do a search on these heads if you have questions about them
The pushrod problem seems to have been corrected at the factory and you can see in the pics they holes are machined larger
There are NO casting numbers on these heads
Google the flow numbers, they are easy to find
$475 shipped
http://i150.photobucket.com/albums/s...S/HPIM1088.jpg
http://i150.photobucket.com/albums/s...S/HPIM1089.jpg
http://i150.photobucket.com/albums/s...S/HPIM1090.jpg
http://i150.photobucket.com/albums/s...S/HPIM1091.jpg
http://i150.photobucket.com/albums/s...S/HPIM1092.jpg
$475 shipped
Re: Pro topline heads - aluminum
You sure those aren't Pro COMP or some other head? All the Protopline heads I've ever seen say Protopline on them and have a casting number.
Car: 92 Firebird
They are the ones off ebay, the seller labeled them "Pro-Race"
Researching them I found that was one of a half dozen names with the most common being Pro topline
If you have a way to distinguish them otherwise, please let me know
No surprises
No surprises
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
those are pro comp, not afiliated with pro topline or RHS, and nowhere near the same quality
Car: 92 Firebird
These are NOT Pro Comp
Pro Comp is a completely different casting
Look at the exhaust side, the mating surface is different
Look at the intake side, Pro comp is drilled for standard and vortec intakes, next look at the intake flange next to the water jackets, again different
Again these are NOT Pro Comp
My heads F/S
![](http://i150.photobucket.com/albums/s98/Pocket_004/Car%20parts%20FS/HPIM1099.jpg)
Pro comps on ebay
http://cgi.ebay.com/ebaymotors/Small...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/SBC-P...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/PRO-C...spagenameZWDVW
And direct from the RHS site
http://www.rhsheads.com/Information/...hevy-Heads.asp
My heads F/S
Pro comps on ebay
I don't mean to bust *****, but Protopline certainly have their name cast into the head. Protopline is NOT the same as ProComp, Pro Action, or any of the other "Pro" prefixed names.
Protopline, now known as RHS, are supposedly superior quality to the other Chinese-cast Pro-xxxxx heads.
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
