305 vortec heads
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
305 vortec heads
For sale, 305 Vortec heads 1996-2002 design. These are the performance heads, not the old style heads. $300 plus shipping. Below are the pictures of them.
Car: 87 Iroc
Re: 305 vortec heads
I know money is tight, but I would really like to have the full payment. Sorry
Car: 1983 G20 Chevy
Transmission: 4L60
Come on guys, somebody with a low-mile 305 TBI needs these. They would make a great improvement over the throttle body heads with the addition of a carb manifold and a carb-tbi adapter. You can leave them un-touched or port the exhaust side. With exhaust porting and the factory peanut TBI camshaft, you can have 300 flywheel HP. Put a nice little cam in it such as the GM Production LT4 and with full exhaust upgrades you can have 315-330 FWHP @ 5,500. Someone needs to grab these 059s before I have to. This is what my last set looked like. I put 265 RWHP down through the factory cast-iron manifolds and factory exhaust in a 1991 Fullsize G20 Van using a 9.5:1 compression ratio and a factory 305 HO cam.
Car: 87 Iroc
Thanks Fast 355 these really are a good set of heads to bump up the power of a 305.Most people dont know that chevy makes 305 high flow vortec heads.
Car: 1983 G20 Chevy
Transmission: 4L60
They are the L30 heads, later 059 castings (2000-2002ish express and marine 305s) from the looks of the pictures. The ports are identical to the L31 heads. The chambers are different though, because they are 6cc smaller. They are shapped much like the older TBI heads but are still classified as a high flow, high swirl head. They do not have a swirl ramp in the floor like the TBI heads, thus flow much better.
If you buy the Vortec style TPI base manifold.
Car: 87 Iroc
As fast 355 has said they will work but for tpi you will have to use a vortec tpi manifold.
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
However, these heads will produce slightly less power due to a less efficient combustion chamber, L31 heads have a heart shaped chamber. You would be surprised how mcuh chamber shape can do for flow.
Car: 1983 G20 Chevy
Transmission: 4L60
You would be wrong sir. The 305 Vortec makes MORE HP/TQ per cubic inch than the 350 does. The 305 Vortec uses the same spark advance tables in its PCM. The 305 heads have the same efficient chamber design as the 350s do. They are just smaller and do not need the little widows peak on the back side away from the plug.
Car: 87 Iroc
Also the spark plug position has been moved to a better location in the chamber for a better burn of the air fuel mix.
Car: 89 IROC/05 RX8
Engine: LS1/LS1
However, i do know the Heart shape chamber promotes a better burn? Maybe its a bigger quench pad? There was an article somewhere that went through the advantages of this design.
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
