1988 complete rear disc brakes $110 shipped
Hey guys! Up for sale this time is a complete set of rear disc brakes from a 1988 GTA. These are off of a 9 bolt. Comes with the rotors (very minor surface rust on one side), calipers, backing plates/caliper mounts, great pads, e-brake cables and the axle brake lines if you need them. In the pics, you can see where the axle seals were leaking, this isn't from the calipers, they worked great until the car was crashed.
I'll do $110 SHIPPED to anywhere int he lower 48. Check the feedback for my username Kwik89GTA. I take paypal and USPS money orders.
Later, Kevin
Later, Kevin
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
Re: 1988 complete rear disc brakes $110 shipped
if i'm buying a 9 bolt disc rearend that is missing the rear discs would this complete the setup? if so i may be interested iif they are still available.
~JAKE
~JAKE
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Do you take money orders ? I wanna change my drum to discs, I know I'd still need the proportioning valve, but how hard could that be to find?
Engine: 2004 LQ4
So is this all what I'd need in order to install rear disk brakes on my car? I know I'd need the rear disc proportioning valve, but this is the brackets, and all the other stuff, right?
Car: 87 Formula 350 / 89 Firebird
Engine: L98 / 2.8 V6
Transmission: 700r4 / 700r4
Axle/Gears: 9 Bolt 3.27 / 10 Bolt 3.42
TTT for a great guy you can trust!
Car: 1986 Z-28
Camarofreak00 , count the bolts on the dif cover. My 86 Z-28 has a 10 bolt. This set up is from a 9 bolt which are usually found in firebirds.
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
it will fit the 86. your brakepads and rotors lines and everything is the same... the rear ends switched out in 88 i thought?? but i guess im wrong because when i ordered rear slotted rotors they asked if it was a 88-92 because they used diff style brakes and rotors.. other than that it should fit right in...
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
novaderrik
08-10-2015 12:44 PM
1992 Trans Am
08-08-2015 08:16 PM
