383 part out HSR, Fast Burns, Comp & more
Car: 2004 Corvette
I am listing the engine items separately from the parting out of my car.
383 short block : Scat 9000 series crank 3.750" stroke 1 piece rear main, Scat I beam rods 6" w/ 7/16" cap screws, Probe pistons .040" over bore. comes with Cloyes double roller timing chain set, balancer, oil pan, timing cover if wanted $1500 OBO
Vortec Fast Burn heads : Fast burn heads w/ cleaned up runners, 26918 Comp springs & retainers SOLD
Comp cams 280 XFI cam .576"I/.571"E lift & 230*I/236*E duration @ .050 113* lobe separation p/n 07-467-8 $150.00 OBO
Comp Pro Magnum roller lifters 875-16 $100.00 OBO
Stealth ram for Vortec heads: Includes the intake, fuel rails, 3 sets of gaskets, S/S ARP bolts, Kirban performance billet AL AFPR that wont leak like the Holley!! Fuel lines to connect to a OEM TPI set up plus fittings, T-stat housing & T-stat, fan switch & coolant sensor for ECM. Billet CSR distributor hold down as well SOLD
Serpentine setup: 4 month old alternator, 1 month old p/s pump, 6 month old water pump, brkts, bolts a/c compressor, smog delete pulley SOLD
LT4 Composite valve covers with mounting bolts & oil cap $240.00 OBO
Holley 58mm TB 112-503 '85-'88: includes modified IAC housing(no coolant bypass), TPS sensor SOLD
AFR Hydra Rev kit: 150.00 OBO P/N 6155
I will include shipping on items except the short block if purchased for my asking price.
pics can be seen here :PICTURES
Chris
Chris
Car: 2004 Corvette
Re: 383 part out HSR, Fast Burns, Comp & more
pretty much everything that is pictured on the parts for sale page. I do need to go through & weed out the sold stuff though.
What are you interested in?
You are 1st inline on the TB
Chris
Chris
Car: 2004 Corvette
I have the right fender & spoiler still. $40 for the fender & $175.00 for the spoiler. Plus shipping. They would go over size.
Chris
Chris
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
How many miles on the lifters?
Car: 2004 Corvette
Chris
