8.5 Disc brake rearend Housing
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
I have a disc brake housing from a 2nd gen F-body(79 TA)...Its been totally gutted and stripped down to just the housing itself. The Leaf spring housing perches have been cut off. The axle tubes have been welded to the center section for added strenght. The outer Flanges will accept 4th gen 93-97 LT-1 style PBR brakes and rotors. The overall length is roughly 3/4" shorter than a third gen rear, so a swap would work rather well. Add your third gen brackets and lift bar set-up and you got yourself a strong rear that will handle lots of HP. I have the axles as well, and will include a pair of 1/4" Iroc factory rear wheel spacers to close up the distance for a near exact swap. Local pickup preffered but could possibly ship if you do the leg work and arrange shipping from your end. I can strap it to a pallet or something and assist in getting it to/on the delivery truck. $75 bucks plus shipping.
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
