383 kit, 350 kit, engine block, pushrods, etc
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
350 Rotating assembly with 210,000 miles on it. Includes crank, rods, and stock pistons. $50 plus shipping.
383 Rotating assembly with 30,000 miles on it. Externally balanced, hyper. Speed Pro pistons, GM X marked rods(supposed to be the best GM made), and Scat crank. SOLD.
Pushrods, Magnum, Chromemoly, Heat-Treated, 5/16 in. Diameter, 7.800 in. Length, Universal, Set of 16. Part number 7372. 5,000 miles on them. $50 + shipping.
350/383 block. Block number is 880, same block from 96-99 trucks. Has been clearanced for a 383 assembly. Have provisions for roller tappet cam as well. Been bored .030 over but needs .010 to be freshened which it will take it and new bearings. Local pickup only or I’ll meet you somewhere in North FL or SE GA…..buyer will cover gas cost. - $200 (+ gas if I have to travel).
Stock oil pan - $20 + shipping
Timing chain cover from 1990 block- $10 + shipping
No Dibs, if someone wants the oil pan, timing chain cover, block, and 383 kit, I will sell it all together and give you the oil pan for free. I am located about 40 miles south of Savannah, GA.
Car: 1985 pontiac trans am
Engine: sbc 355 with comp cam and promag ro
Transmission: 700r4 with 2500 stall
Axle/Gears: stock 9 bolt for now.
Re: 383 kit, 350 kit, engine block, pushrods, etc
does the 350 have the intake and is it a 4 bolt main
Car: 02 WS6, 83 WS6, and 78 Project
Engine: LS1, LG4, and 400
Transmission: 4L60E, T5, and TH400
Axle/Gears: 3.73, 3.73, and 2.73
Is the sale still pending on the 383 rotating assembly?
theshackle
03-05-2017 06:37 PM
NinjaNife
08-23-2015 11:49 AM
