.040 SILV-A-LITE PISTONS
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
FROM AN ABORTED STROKER, BLOCK HAD A CRACK IN THE WATER JACKET. IT WAS RUN, BUT NOT FOR VERY LONG. SO THE PISTONS ARE USED, BUT WITH LITTLE TO NO MILAGE ON THEM. $125 SHIPPED. CALLING IS THE BEST WAY TO GET THESE!!!!
559-213-2752
THANKS
559-213-2752
THANKS
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: .040 SILV-A-LITE PISTONS
Are these for a .040" over 4" bore or a 4.125" bore? What rod length? What stroke?
I AM NOT SURE, OF THE SPECKS, BUT I CAN MEASURE THE ROD LENGTH AND THE DIAMETER OF THE PISTON, BUT I HAVE NO CLUE AS TO THE STROKE. SEEMS TO ME TEY CAME OUT OF A 350/400 STROKER, BUT NOT COMPLETELY SURE. I GOT THE MOTOR AND TORE IT APART TO CHECK IT OUT, AND FOUND THE BLOCK CRACKED. BUT I CAN'T REMEMBER WHICH ONE IT WAS, CAUSE I HAVE HAD TWO OR THREE OF THEM(ALL CRACKED, NO MORE USED STUFF FOR ME, I AM BUYING A GM BUILT STROKER NOW). I JUST FOUND THESE IN MY GARAGE AND WOULD LIKE TO GET RID OF THEM OR I AM JUST GONNA TAKE THEM TO THE LOCAL RECYCLER AND SCRAP THEM. I WILL POST LATER WITH THE SPECKS
Transmission: 200R4
Check to see if there may be a part number on the underside. Pictures would be good too.
6602 OR 6607 CAN'T REMEMBER WHICH ONE FOR SURE, IT IS ON THE SIDE OF THE PISTON, OTHER SIDE HAS THE SILV-A-LITE ENSIGNA, I PROBABLY WON'T BE ABLE TO UPLOAD PICS TIL AFTER THIS WEEKEND, AND I THINK THEY ARE PROBABLY CAST PISTONS NOT FORGED
HOPE THIS HELPS
ERIC
HOPE THIS HELPS
ERIC
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
Dragonsys
09-25-2015 03:51 PM
