Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...
Old 04-14-2007 | 11:18 PM
Phatfiddler's Avatar
I am moving to Orlando next month, which is a full 8 hour drive away. My company is reimbursing me for my moving expenses, but I must first pay for them.
  • Single-Plane, high-rise aluminum intake
  • aluminum fuel rails
  • Billet aluminum 1000 cfm throttle body with progressive linkage
  • Kick-down bracket for auto transmissions
  • 8 30# low impedance injectors
  • Turbonetics carb hat
  • K&N cone filter
  • Aluminum intake tubing
  • 2 Fuel rail mounted AFPRs (not sure if works)
This setup uses GM sensors and can replace a TPI setup. The intake used to be black powdercoated, but I had it sandblasted. The intake, throttle body, and fuel rails are aluminum. The rust spots in the coolant passages is from the iron block, so it just needs to be scrubbed with some cleaner.
I did not make this setup myself! This is the same Holley Single-Plane MPFI that you can buy from Summit and various other racing stores. The center-bolts are angled for late style heads, and the ports are standard and match a FelPro 1204 intake gasket, but it can be ported. The only difference is the name. This setup was made by Cutler, the company Holley bought several years ago, and now sells the same stuff under the Holley brand.
This setup can be considered rare since is one of the first aftermarket EFI setups that could be purchased. Almost everyone has a Holley or Edelbrock, but how many do you know of that have a Cutler?
If you are interested, make me a reasonable offer. I am looking for somewhere in the field of $1,000 for everything , but will accept lower as long as its reasonable. The carb hat alone sells for around $130. I will offer FREE shipping if everything is purchased for around $1000.
I also have the bracket that lets you use the intake with an automatic transmission like the 700R4 that uses a kickdown cable, which I will include as well.
Attached Thumbnails Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...-p4140199.jpg   Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...-p4140200.jpg   Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...-p4140201.jpg
Last edited by Phatfiddler; 04-20-2007 at 06:23 PM. Reason: Added pictures, updated description.
Old 04-15-2007 | 04:21 AM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Re: Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...
picture link doesn't work.
Old 04-15-2007 | 10:22 AM
More pictures...
Attached Thumbnails Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...-p4140202.jpg   Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...-pb110035.jpg   Gauging Interest: Single-Plane MPFI, 4-barrel throttle body, carb hat...-pb110040.jpg
Old 04-16-2007 | 04:19 PM
To the top
Old 04-19-2007 | 11:23 PM
Bump bump
Offers from anyone? I really need this stuff gone....
Old 04-26-2007 | 07:48 PM
400CI87Firebird's Avatar
Car: 1987 pontiac firebird formula ws6
Engine: chevy 400 cubic inch V8
Transmission: turbo 350
hey is your mpfi setup still available? also are you already in orlando because i life like 40 mins away. do you have any of the wiring and sensors for it too? Thanks-Tom
Old 04-28-2007 | 10:28 PM
Hey. Sorry for the late response.
I won't be moving until mid/late next month. I still have everything as mentioned in the previous posts, and I have most of the sensors. I'll have to double check since I removed them to clean the manifold. I do not have a harness though. I was planning on having a custom one made so that I could use the LS1 411 pcm. This will, however, also work with a TPI harness if you have one. You could also repin a TBI harness to work as well. Thanks for looking!
Old 05-14-2007 | 10:14 PM
you have a pm
Old 03-01-2010 | 09:53 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Carb hat still available?
Old 03-01-2010 | 10:35 PM
bonesbrakr's Avatar
WTF another canadian not looking at post dates.... This thread is almost 3 YEARS OLD!!!!!
Old 03-01-2010 | 11:44 PM
Kwijybow's Avatar
Engine: Carb'd 305
Lol, yeah. Thought I'd try!
Just kidding, I didnt notice the post date until after I posted my reply and then...I just didnt care enough to delete it. LOL!
Azrael91966669
25
06-20-2017 05:04 AM
mdtoren
08-16-2015 06:45 PM
bamaboy0323
08-15-2015 08:20 AM
