TNT F1 Nitrous Wet Kit 75-150hp Never Used
Car: 1988 GTA
Transmission: TH350
TNT F1 Nitrous Wet Kit 75-150hp $400
For sale is a Texas Nitrous Technology (TNT) F1 Nitrous Wet Kit adjustable between 75-150hp. Kit is designed for an LT1 with adjustable throttle cables but I am including the plate from Holley to extend the cables on a TPI setup. Kit has never been used, just removed from package. Kit includes everything seen in the pictures plus all the jets (not pictured) from 75-150hp. I would like to get $400 for the kit since it sells brand new for over $700.
All info needed can be found at
http://thunderracing.com/catalog/?ac...vid=4&pcid=161
towards the bottom of the page
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Will it fit a TPI? I dont know if the LT1 and the TPI throttle bodys bolt up the same.
Car: 1988 GTA
Transmission: TH350
Yes it will fit a TPI setup, I'm including a special plate to convert the kit to be used on a TPI setup. Its pictured in the 3rd picture
Car: 1992 25th Anniversary White W/ Red
Engine: Procharged 383CI/ Soon LS2 Turbo
Transmission: Manual 700R4
Axle/Gears: 4:11/Auburn Posi/Moser Axle
if you still have this in a few weeks ill buy just dont have the cash right now
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Just got this yesterday in the mail. Everything is here and looks ok, aside from the relay or whatever it is (the little black square thing) which has some oxidation on two of the prongs. It looks like that part has been used before (and I'd imagine the same thing about the rest of the kit), but if it works then I'm not gonna bitch. Thanks FactoryFreak
FactoryFreak
32
01-08-2007 09:26 PM
