Comp Roller Cam, 355 Short Block, Holley Commander, Supercharger "magnacharger"
Custom Comp Roller Cam & Supercharger "magnacharger"
1. Comp Cams Custom ground hydraulic roller cam .544 I .556 E 230 I 236E 114 lope separation. New $270
2. Custom Eaton M112 supercharger setup. All parts are new and custom built. It is very similar to a Magnacharger setup. This unit is not completely finished, it still need an air intake duct fabricated from the throttle body to the back of the blower. The manifold, fuel rails, blower mount and serpentine drive are all completed. This is the same style and size blower that mustang cobra use to make over 540 hp to the rear tires $1200.
Thanks for looking
Thanks for looking
Last edited by 355SS; 01-24-2007 at 08:45 PM. Reason: Serpentine,commander,shortblock and ignition parts are sold
Car: 85 T/A
Engine: BBC
Transmission: glide w/brake
Is that a lightning 112? What did you use for the lower intake? Is it for vortech heads or the old pattern heads, I can't tell from the pic.
Very cool, looks great
I have not finished the air intake from the back of the blower to where the throttle body would be located. I am using the M112 off of a jaguar, I purchased it new. I choose this model since it is the more efficient rear inlet and is more compact than the cobra model. I have finished the lower intake, fuel rails, serpentine belt drive and it all fits under a stock hood. The intake is for a non-vortec sbc. All of the parts were purchased new (blower, 60 lbs injectors, fuel rails, manifold)
junkcltr
08-02-2019 11:12 PM
ambainb
04-25-2016 09:21 PM
