GMPP 350 crate engine. Make Me an offer!
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Well I have a GMPP 350 that has been sitting on an engine stand for 2 months. Nothing is wrong with it, I took it out for a 383 stroker. The lower end is all stock. It has a crane energizer cam in it, Ported and Polished heads, Heads have been milled to 66 CC. Heads have roll pins machine into the base for the higher lift cam. The valves have a race 5 angle valve job. It comes with a HEI dist. with MSD coil. Has a Edelbrock preformer intake that has been port matched to the heads. Comes with a chrome timeing cover (needs to be installed). Has chrome valve covers. Comes with flexplate, Water pump, and Holley 650 carb. I am doing a turbo 350 swap, and need money. I will not ship the motor. A huge PITA. I am in NY zip 12566. Make me an offer over 750 bucks. I have well over 2000 invested. would like 1200 but I dont think im getting that. It has about 7500 miles and dyno'd at 298 rwhp threw a 700r4 and 10 bolt.
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Yes I do, I have all the parts to rebuild it. I need a stall verter' D/S and x member. What type of deal are you thinking?
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
TTT, send me your email and I will send pics.....
Need to get rid of, Will take 1000!!!! Complete from oil pan to intake! from water pump to flex plate!
1 Post
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
fastcarmo@hotmial.com why did you go carb? thats one consern i have i like fuel injection better
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Fuel injection is more expensive to do. Plus when I got my IROC the harness was all screwed up. I had everything to do the swap in my basement. Plus my car is for the 1/4 mile, really not for the street.
Where are you located?
*EDIT* I cant find any pics on my computer. Im going home thursday and I will post them. If your local you can come take a look at it. Basically imagine a SB that the block is sliver, heads and intake are black, with chrome bolts and valve covers.
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
mcquigg
08-13-2015 02:26 PM
