Jacobs Nitrous Mastermind
(Jacobs Nitrous Ignition Controller - Nitrous - Lowest Prices!)
Can prevent detonation, burned pistons, over-revving, and more. Bought it used a few years ago but never installed it. Has the fuel pressure switch for carburated applications, but you can easily replace it with one for EFI. $100+shipping from St. Louis, MO.
email me at neumo.rama@gmail.com
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
got any pics of the actual unit, id like to see how the wiring is on it and the different adjustment settings, the advirtisement pics are kinda weak
Here's some pics:
http://userfs.cec.wustl.edu/~jsn1/images/IMG_1764.jpg
http://userfs.cec.wustl.edu/~jsn1/images/IMG_1765.jpg
http://userfs.cec.wustl.edu/~jsn1/images/IMG_1768.jpg
http://userfs.cec.wustl.edu/~jsn1/images/IMG_1771.jpg
You can check out the wiring in the manual at:
Jacobs Electronics
The unit comes with a fuel pressure switch for carb'd applications, which should be all you need.
Jacobs Electronics
CarGuyDennis
137
12-06-2016 11:02 PM
