LT1 block and worked heads
I have a 1995 LT1 disassembled engine out of camaro. I had a bunch of work done but decided to scrap the project car.
Work that was performed to Block and heads as per invoice
Boiled block, replaced core plugs
Change block to 4 bolt mains
Line bore + hone mains
Rod Clearance block (383)
Deck square
Bore + hone w/ stress plate
Washed for assembly
Installed cam bearings
4 Steel main caps
1 set ARP main bolts
1 set cam bearings
Heads were done by Brandywine Cylinder Heads
Cleaned heads
Port work
Flow+cc work
Comp valve job
8 REV intake valves 2.02
8 REV exhaust valves 1.55
Flow numbers
Intake
300 =186cfm
400 =231cfm
500 =258cfm
600 =255cfm
700 =255cfm
300 =150cfm
400 =171cfm
500 =180cfm
600 =189cfm
700 =192cfm
800 =195cfm
Crame cam valve springs, retainers, lock kit
Setup for the GM 847 cam
Intake was milled
I have over 4,000 invested..... looking for 3,000 or best offer
I also have the stock parts( old crank rods,pistons, valve covers ect….that will be included if you want them
Located near Morristown, NJ
local pickup if possible. I rather not ship
Deck square
Washed for assembly
4 Steel main caps
1 set cam bearings
Cleaned heads
Port work
Flow+cc work
Comp valve job
Flow numbers
Intake
300 =186cfm
400 =231cfm
500 =258cfm
600 =255cfm
700 =255cfm
300 =150cfm
400 =171cfm
500 =180cfm
600 =189cfm
700 =192cfm
800 =195cfm
Intake was milled
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: LT1 block and worked heads
What happened with the heads, still got 'em? If so, what are you asking?
Why won't you ship?
Thanks,
Jake
Why won't you ship?
Thanks,
Jake
Car: 1991 z28
Engine: forged 385 with afr's
Transmission: built 700r4
Axle/Gears: 9" and 4.56
how much for the block? you said it was bored? how much?
1 Post
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
mp3coupe hasn't been on the board since Oct. 13, 2006. Prolly not going to get an answer.
Axle/Gears: 3.07
1992 Trans Am
08-08-2015 08:16 PM
