2.8, 3.1, 3.4, V6 Parts!
I've got some leftovers from my 6 cylinders...
Fiero aluminum valve covers... No gaskets, no hardware, need to be cleaned up and refinished. $65
Fiero intake bolt set... Full set of 12 point chrome intake plenum bolts from a Fiero 2.8. Will also work on Camaro/Firebird 2.8/3.1. $15
2bbl carb, non-computer controlled. Came off an S10 or similar, identical to Camaro/Firebird 82-84 carb but without ECM control. $40
Clutch set, flywheel, pressure plate, disc, and throwout bearing. Flywheel was turned and disc was installed, engine blew up a few weeks later. Disc is a solid hub racing disc, everything else is typical OEM. Stock feel with racing performance. $100
T5, bellhousing, shifter, clutch fork, etc. Worked excellent when pulled. Ready to install. $200 Buy the tranny and I'll throw in the clutch set free.
Also of interest to the V6 crowd, I've got some beefy sway bars for $50, and a 82-89 Camaro guage cluster with full guages, $50.
All prices are plus shipping. I don't check replies typically, or PM's... Email me for best results. predatorman@hotmail.com Pic's available on request
Springster
09-13-2015 01:38 PM
