Sensors, ECM, coils, timing chain, mounts etc. LOOK!
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi, I have all these guys for sale.
1.Gray inside door handles, great condition
2.Transmission Poly mount.
3.160 degree, high flow thermostat
4. 2 TBI 305 injectors
5.Assorted gaskets for the TBI, the bottom one in particular. Also few little rubber rings and fittings. (really not complete, just few I did not use, and the bottom ones are deffenetly brand new never used).
6.New bottom radiator hose (no spring, I think you have to add that).
7. Barely used Borg Warner cap and rotor.
8.Fuel guage, no wires, but never used.
9.Fuel pump relay, front clip damaged, but it was working fine when I pulled it.
10.3 map sensors, all working to my knowledge
11.Noise supressor for your AMP.
12. Two 180 degree thermostats. One has a small hole, the other just a bit bigger hole (I drilled them with small bits).
13.IAC, used, but works great
14.TPS sensor, used but works great
15.Light cover for the roof (T-top and hard top)
16.2 berlinetta letterings (from a berlinetta car I found in the JY, good condition).
17.Felpro manifold gaskets (new, only used one gasket, which is missing, and it was one of the end pieces). Good to add to the collection of people who use these for headers.
18. NEW AC DELCO PICK UP COIL, BOUGHT FROM A DEALER.
19.TBI computer, works great (pulled it cuz I though there was a problem, but I was wrong,(Just a tired motor) the ECM works great).
20.Hood pin kit (new)
21.Clevite timing chain (new)
22. Knight rider light (jc whitney one).
I also have
two gray seats (which I can part for tracks only)
Driver side front bumper GFX (the flat bumpers), side GFX.
Send me some requests you have, I just might be able to get some stuff for you.
Give me offers, and shoot any questions you have.
I use pay pal. If you want something Pm me first, then as soon as I recieve the payment I'll send the items.
My ebay name is xlwhellraiser69 and you can check out my feedback 100%, I've been on these boards for a while, so buy with confidence .
I also have
TTT.
I find it HARD to belive that no one wants any of these parts.
Let me know!
Best offer takes 'em.
Let me know!
Well, I ordered it for my 350 LO5 motor. So, I think its roller.(also goes with the 350 TBI motor). Here is a pick.
part number is C3023K
Sorry about the jeans, but I just took it out of the box to take a pic and was running out of batt. So, I snapped it over the jeans .
Checked it and its Cloyes, roller timing set!
There are some parts you can get for waaay cheaper, and are not even used.
TTT.
TTT.
9192camaro
16
02-03-2019 12:21 AM
92camaroJoe
08-13-2015 06:07 AM
