Holley twin 58mm throttle body
Car: 1987 Trans am
Engine: Cammin Ls1
Transmission: Th400 w/brake 5500 stall
Axle/Gears: Moser 9" w/ 4.11's
$265 shippedHolley twin 58mm throttle body with new tps sensor($40) and new IAC valve($43) has about 1500 mile on it and is basically brand new $315 shipped obo
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
Summit has that BRAND NEW for $350.00
I'm also willing to pay $250 if things don't work with previous offers...
Car: 1987 Trans am
Engine: Cammin Ls1
I understand it is 350 new and it is basically brand new with a brand new iac sensor and tps sensor which means i have $430 in it and if you look at how new the gasket looks it was only run about 1500 miles and had absolutly no flaws what so ever. I will do $280 shipped for whoever wants it. I can guarentee that you will be 100 percent happy with it.
Car: 1991 Z-28
Engine: AFR ELIM 195s,280xfi,58mmLt1 Intake
Transmission: 2200stl,700r4 shift kit,vette servo
Axle/Gears: 28 spline, 3.42 gears, SLP Posi
is this tb for maf or map cars?
Car: 1987 Trans am
Engine: Cammin Ls1
It is for either. when i bought it first it was on my maf car then i converted to map so it will work the same on either.
9192camaro
16
02-03-2019 12:21 AM
mdtoren
08-16-2015 05:45 PM
