SD TPI painless harness
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: whatever has the most gas in it
Engine: GM v8
Transmission: Uumm that's contingent
Axle/Gears: See prior line
Hey, I' selling a Painless TPI harness (speed density) along with the matching ECM(7730). It has a custom chip from TPIS set up to run a 355 a small block w/24 lbs injectors small cam, runners, 58mm throttle body,etc
This sale is only for the Harness, chip, ad ECM.
$250.
I also have a MAP sensor and distributor if your looking to upgrade from the horrible MAF style setup.
$250.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Is the harness new? Is it complete with instructions? What else would I need to convert to Speed Density from my MAF set-up?
Thanks.
Thanks.
Engine: GM v8
Thanks.
Thanks.
Transmission: 200R4
PM again. I also forgot to ask if the ECM must be used with a specific transmission....auto or manual?
Thanks.
Thanks.
Engine: GM v8
Ok, great!
Give me a day or 2 so I can sit down and label weverything for you, I'll write up some directions to make it easier for you as well.
thanks
J
thanks
J
Engine: GM v8
Hey bud, I returned your PM. I'll check the tracking # when i get home and I'll shoot you a PM. PM me if you have any question.
Sanjay
08-12-2015 03:41 PM
