F/S PRO TOPLINE VORTEC HEADS, COMPLETE!!!
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
Hi,
Is anyone intrested in a set of pro topling vortec heads?
I just bought them and found out there not going to work with my set-up.
Here are the details on them.
COMPLETELY REMANED BY AN ASE MASTER MACHINIST. THEY HAVE BEEN BAKED AT 625 DEGREES AND SHOT PEENED. FOLLOWING THAT THEY HAVE BEEN MAGNUFLUXED TO ENSURE NO CRACKS(THERE WERE NOT ANY) THEN THE STUDS WERE INSTALLED. BOTH OF THE GASKET SURFACES HAVE BEEN MILLED TO ENSURE PROPER SEALING THE INTAKE ONLY HAD .004 TAKED OFF. THE VALVE GUIDES WERE THEN REAMED .015OS AND THE SEATS WERE CUT WITH A THREE ANGLE CUTTER. THE FIREDECK HAS BEEN MILLED .012. THE HEADS WERE THEN WASHED AND ASSEMBLED. THE VALVES ARE 1.94 AND 1.50 THEY HAVE DYNO TIME ON THE VALVES ONLY. THE SPRINGS ARE NEW AS ARE THE RETAINERS AND THE LOCKS(THEY ARE .030 HIGHER COMP. THAN FACTORY) THE VALVE SEALS ARE VITRON UMBRELLAS. THE CHAMBER CCS ARE AROUND 68, RUNNERS ARE, I BELIEVE, 180.
Looking to get what I paid for them $520 shipped
Let me know if anyone is intrested.
Thanks, JR
Thanks, JR
TTT
I'm not sure how far they could be milled down.
But I think they could be.
Anyone what to chim in with an answer?
All post in a section of the board asking
to try and get a quicker answer.
Thanks, JR
Thanks, JR
I have all ready bought a new TBI intake
and rather than sale the intake and matching
throttle body I just want to sell the heads and buy the right ones.
Thanks, JR
Thanks, JR
Car: 92 RS Camaro
Engine: 305 TBI
ive got a L03 and the combustion chamber size is 58 cc on stock heads, putting 68 cc heads on my engine would drop the compression way too low.
TGO Supporter/Moderator
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
-- Joe
I have a 350 I'm building up.
Originally Posted by anesthes
About .076" can be taken off (angle mill), which puts the valve angle at about 22* and makes tons of power.
-- Joe
-- Joe
JR
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Protoplines have super thick decks. They can easily be milled to 58cc. Bump for a nice set of heads. They have improvements over the standard Vortec. They came cast for studs, improved cooling, thicker decks and more meat in the ports for additional porting. I've got mine angle milled to 60cc with no problems.
84z96L31vortec
08-20-2017 12:16 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
