TPI L98 LT1 Nitrous Spray Bar Plate w/ bolts and gaskets
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Asking 85 shipped, this is one nice unit, comes with the hex bolts and the gasket.
Does this come with any jets? If so what are the sizes. This uses the 'standard' type of jets correct and they are installed where the hard lines are attached to the bracket correct? Interested so let me know. Thanks!
Mike
Mike
I will include a pair of jets for a 125 shot just let me know what fuel pump and pressure you run. It uses standard NOS type jets, NOT the funnel jets. The lines connect at the end of the hard lines, this is nice because you don't have to wedge in there to change out jets; the connection lines are 3an fittings. Hope this helps.
Hotrodboba400
12-10-2019 07:07 PM
KO1
16
10-15-2015 05:00 PM
