[DE] T56 retrofit replacement for T5 , Muncie, Lakewood, etc.
Old 03-19-2009, 08:05 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
SOLD -Still 2 cores available from next to last post
Freshly Rebuilt, Zero Miles on rebuild.
This is a Retro Fit T56, built for adapting the strength and performance of the T56 transmission, to older GM style bellhousing, clutch, and linkage setups. The transmission was completely torn down and inspected. The adaptor will bolt to the T5 bellhousing of your thirdgen and retain use of the stock linkage. Can also mount to a straightup bellhousing like a Muncie, BOP, or standard SFI (lakewood, etc.) 4-bolt bellhousings.
Here are some of the main features:
* Standard stronger LS1 T56 gear ratios, using LS1 input shaft
First: 2.66
Second: 1.78
Third: 1.3
Fourth: 1
Fifth: 0.74
Sixth: 0.5
Reverse: 2.9
* Carbon Fiber synchro blocker rings
* New Synchro keys, springs
* New Fork pads
* Front steel adapter plate drilled for both Muncie/T10/saginaw bellhousing, and the 18deg rotated bellhousing used by the T5 Camaro/Firebirds
This is a high quality rebuild with the highest level of attention to detail. Here are the main shimming specs that were used for a performance rebuild:
Main shaft: 0.002" Preload
Counter shaft: 0.003" Preload
Counter shaft extension: 0.002" End-Play
Case and all parts were cleaned and inspected. The case was not sand blasted to keep grit out of the internals.
Local pickup (19711) is preferred, but shipping would be $100-$150 depending on your location.
Please feel free to contact with any questions.
$1600 + PP fees + S/H (About $130)
Old 04-01-2009, 07:46 AM
85MikeTPI's Avatar
Re: T56 retrofit replacement for T5 , Muncie, Lakewood, etc.
Still forsale.. Make a resonable offer. Can be custom-updated for cost of parts.
Old 05-08-2009, 02:09 PM
85MikeTPI's Avatar
Price reduced
Old 05-12-2009, 02:40 PM
85MikeTPI's Avatar
And I still have the LT1 inputshaft and midplate for this. If anyone wants just a simple LT1-T56, I can convert this unit back for the same price.
Old 05-22-2009, 08:01 PM
Clutch-Burner18's Avatar
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 3.45 borg warner
Im interested in your transmission. How much torque can the transmission handle?
Old 05-23-2009, 07:58 AM
85MikeTPI's Avatar
The unit is factory rated at 450lb-ft, but they have been known to handle upto 550-600lb-ft without problems. Alot depends on the driver and the weight of the car. It can be upgraded with parts to bring it up over 700lb-ft.
Old 05-23-2009, 08:41 AM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
So the trannmission your selling is rated at 450 ft-lbs? Also how much would the parts cost to attain around 600 ft-lbs?
Old 05-23-2009, 09:50 AM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
will this require a different driveshaft than the one in a car with a t-5 and will it also require a different crossmember?
Old 05-23-2009, 10:13 AM
85MikeTPI's Avatar
The unit could probably hold 600lb-ft, (again, depending on driving habits and car weight) but would be pushing the envelope.
The upgrade parts are:
- steel 3/4 shift fork
- Billet synchro keys
- Bronze shift fork pads
I usually get my parts from http://www.thegearbox.org/T56.html. I usually recommend billet keys on 1/2, and 3/4 at a minimum, and usually put them on 5/6 also for my hipro rebuilds. I like to put the bronze pads on all four forks, since they are all prone to wear. Upgrades would be between $300-$500.
Old 05-23-2009, 10:15 AM
85MikeTPI's Avatar
Yes, this requires a modified driveshaft, torque-arm, and crossmember.
http://www.gilbertchevy.com/BorgWarner/bwt56pics.cfm Has one of the early write-ups on the factory retro-fit unit. The one I have is the same except the shifter location is stock '93-'96 fbody.
Old 05-24-2009, 09:49 AM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
So to clarify, if i were to bolt up this transmission, i could reuse my current flywheel, bellhousing, clutch assembly, master cylinder, and current shifter boot placement from my t5 setup? Also how hard would it be to upgrage those few parts if you have never worked on a transmission before without screwing up any tolerances or things of that nature? And does your transmission come with a shifter, if not any suggestions?
Old 05-24-2009, 01:07 PM
85MikeTPI's Avatar
You can reuse your current flywheel (26-spline), bell, clutch assm, MC. You will have to lengthen the tunnel hole and bolt a piece of steel onto the shifter to move it back to the stock location. I don't have anymore stock shifters left, they are usually available on Ebay for ~$20.
Both Spohn and SPD sell Xmems for the retrofit, if you don't want to cut/weld one. Spohn even sells a torque-arm also if you want to upgrade from the stocker. The driveshaft shortening should be left to a driveshaft shop. They will cut and reweld, then rebalance the shaft, and not a DIY job. Most of the aftermarket DS shops will build a custom length DS also. (Dennys, etc.)
Old 05-24-2009, 02:05 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Ok well im definitely interested. I would like the transmission to consistently handle around 600 ft lbs of torque. If we struck a deal, would you be willing to upgrade the transmission accordingly?
Old 05-24-2009, 04:51 PM
85MikeTPI's Avatar
Yes, I can upgrade the TQ capacity of the trans for just the price of the parts.
Old 05-24-2009, 05:03 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Could i have a price estimate for the upgraded transmission?
Old 05-24-2009, 06:09 PM
85MikeTPI's Avatar
Required:
Steel 3/4 shift fork - $45
Billet 1/2 shift keys - $45
Billet 3/4 shift keys - $60
Bronze pads, 1/2 & 3/4 - $53
Extended pilot bushing - $22
Recommended:
Billet 5/6 shift keys - $60
Bronze pads, 5/6, Rev - $53
Bronze shifter cup - $25
Optional:
Billet Rev shift keys - $60
(shipping charges will be required for the parts order also)
Old 05-24-2009, 06:14 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Ok that sounds reasonable. And how much for the transmission itself?
Old 05-24-2009, 06:58 PM
85MikeTPI's Avatar
The original post was updated when the price was reduced to bottom-dollar:
$1600 + PayPal fees + S/H (About $130)
Old 05-24-2009, 07:28 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Ok that sounds reasonable. My dad wanted me to check, though, if you offered any guaruntee with the transmission.
Old 05-25-2009, 08:09 AM
85MikeTPI's Avatar
While I don't/can't offer any warranty, I won't leave you hanging. I've been on the boards here for over 10 years, and won't be disappearing.
Old 06-01-2009, 04:47 PM
Car: 87 Iroc z
Engine: 305 tpi
Transmission: t-5
Well I've talked it over with my father and I'd like to purchase the transmission. Would you take $2200 for tranny+cost of upgading tranny+pp fees+shipping? Email me at jspeedy90@gmail.com if that works.
Old 06-03-2009, 01:59 PM
85MikeTPI's Avatar
Sale Pending...
I may have an LT1 core and a GTO core in the next 2 weeks, if anyone is interested in either, or a retro-adapted from either.
(Clutch-Burner18, I emailed you, but never heard back???)
Old 06-05-2009, 02:13 PM
85MikeTPI's Avatar
Sold. First post updated.
Old 06-18-2009, 12:35 PM
luke j's Avatar
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
how much for lt1 core?
Old 06-19-2009, 07:09 AM
85MikeTPI's Avatar
$500 + S/H
Old 06-19-2009, 09:01 AM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
whats the specs on the gto core and how much?
Old 06-19-2009, 09:08 AM
85MikeTPI's Avatar
What specs are you looking for? I haven't received it yet to know what's wrong with it (reported to have 3rd gear issues). It's a stock MN12 GTO unit if you're looking for gear ratios?
Old 06-20-2009, 12:29 AM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Jus the normal ls1 specs, lookin for a six speed. tryin to get it cheap i can always get it rebuilt
Old 06-20-2009, 10:45 AM
85MikeTPI's Avatar
The GTO is the same externally (shifter/VSS/mounts/bellhousing/clutch/etc.) as the LS1-Fbody T56. Internally, it has upgraded synchros and a wider gear ratio for the heavier GTO car.
LS1/MM6 vs. GTO/MN12
1st Gear 2.66:1 2.97:1
2nd Gear 1.78:1 2.07:1
3rd Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
Old 06-20-2009, 11:13 AM
Car: 85 trans am
Engine: 383 stroker
what kind of power is the gto core good for when its rebuilt?
Old 06-20-2009, 07:13 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
how much for the gto core?
Old 06-21-2009, 09:15 AM
85MikeTPI's Avatar
The GTO unit is rated at the same power level as the LS1 (450lb-ft) and can accept the same upgrades to push it to the 700lb-ft level. The 2.97 gear set isn't a weak link like in the '93 LT1 units because the thickness of the gears was increased to offset the taller ratio teeth.
I probably won't have the core until next week or so, but I have $600 into it if someone wants to take it for that, I won't lose anything on it. I have a limited number of MN12 replacement parts, so I could tear it down for a repair estimate for a little more.
Old 06-21-2009, 01:05 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Can you get me a quote for it shipped to 06770? Im interested now and badly wanna drop a 6 speed into my iroc, exspecially with my 5 speed leakin due to a cracked unit
Old 06-21-2009, 01:41 PM
85MikeTPI's Avatar
PM sent
Old 06-21-2009, 04:44 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
PM sent back
Old 07-29-2009, 12:09 PM
jonnybcamaro's Avatar
Car: 02 T/A
Transmission: Built 4L60E
Axle/Gears: 3.42 Posi
I am wanting a T56 Retro fit, You say that you have an Lt1 core, do you still have it? and can you use an adapter plate on it to make it work like the Retro fit?
Old 07-29-2009, 01:42 PM
85MikeTPI's Avatar
You need to swap the LT1 input shaft for an LS1 input and cut off/down the TOB sleeve, but otherwise yes, you can put the plate on and use it as a retrofit. The GTO trans would adapt to the plate directly, but has different gears and better synchros than the LS1 unit.
My spreadsheet says I have one LS1 input shaft left in my parts pile, I'd have to verify if you wanted it.
grngryoutmyway
10-18-2016 05:48 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
RedLeader289
09-23-2015 06:50 AM
Abubaca
09-20-2015 09:35 PM
383cam
09-09-2015 06:01 AM
Quick Reply: [DE] T56 retrofit replacement for T5 , Muncie, Lakewood, etc.
