6K 6 cyl tach for V8
Old 03-25-2002 | 01:36 AM
ZZsmpch's Avatar
I did a search on swapping in a 6000 RPM redline tach from a 6 cyl 82-89, and saw some folks said it didn't work. I did the swap today and it turned out good. You just need to swap the board on the tach from your 8 cylinder onto the 6 cylinder tach. It's pretty easy. Just remove the nuts on the gauge lugs and swap it over. I still need to swap the oil pressure gauge over so it's got the 60 PSI instead of the 80, but that's no big deal. I did verify the tach reading with a scan tool to make sure it was acurate and it was within 50 RPM at 4000 RPM. Just thought I'd pass this along. It sure looks a lot better than that lame 5000 RPM redline tach.
Old 03-26-2002 | 11:09 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yes, you can swap the faceplate over, that's easy enough to do. Usually that involves removing the needle and recalibrating the gauge though.
Old 03-26-2002 | 11:15 PM
ZZsmpch's Avatar
I didn't think of taking the faceplate off. After swapping the circuit board though, the tach was pretty accurate according to my scantool. Do the needles just pop off?
Old 03-27-2002 | 09:11 AM
99Hawk120's Avatar
Yes, but they're annoying to get back on correctly. If you were able to do it without removing the needle, that's great. Swapping the circuit board should work fine.
$750 L98
11-07-2015 03:26 PM
bjpotter
10-04-2015 08:48 PM
Eric-86sc
09-28-2015 12:37 PM
armybyrd
09-15-2015 07:06 PM
TrevinE
09-14-2015 04:20 PM
