Electronic Flasher Relays not helping since LED upgrades
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 700 R4
I've installed the following LED components, but the turn signals and hazards are not working.
- Digi-tails LED tail lights
- Lasfit 1157 Switchback LED Front Turn Signal Parking DRL Light Bulbs
- LED side marker strip lights - www.ebay.com/itm/403425254536
- grounded electronic AMFRNE 2 Pin LED Flashers (I originally tried non-grounded LDMINDA 2 Pin Electronic LED Flasher Relay)
With the old aluminum flasher relays, the components light up solidly. When I put in the electronic flasher relays none of the signals flash or lights up. I should mention that the running lights, and brake lights all work perfectly fine.
To add, my horn, or reverse lights do not work, in case they're related.
All fuses are checked and replaced and I've regrounded everything I could find. It's a LS swapped LS car, and I've found quite a bit of questionable wiring on the car. Where should I look next? Getting beyond frustrated and confused; especially because wiring is not my specialty.
Re: Electronic Flasher Relays not helping since LED upgrades
i had the same problem when i switched to eBay LED taillights I got the taillights too work with the head light switch on but no brake light. then i read that the 87 trans am Brake lights ran thru the hazard flasher relay, so I replaced that then my turn signals and flashers on the front worked but not the rear and still no brake light. about too got thru the rear wiring with a multi-meter lol, is there anywhere else I should look in too??
Fenrir
11-07-2018 11:12 PM
