Stock radio install no power at orange
Old 09-17-2022, 10:20 AM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
I am Hooking up my stock radio 88 gta. I am not getting 12v at the orange and fuse is good. I am waiting on my wiring diagrams to be delivered. In the meantime can anyone tell me where I should be looking next. Appreciate any help
Old 09-17-2022, 10:34 AM
Received 1,718 Likes on 1,308 Posts
Re: Stock radio install no power at orange
CTSY fuse
Old 09-17-2022, 10:52 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Axle/Gears: Stock / 4:11 Moser 9"
Replace the fuse even if it looks OK just to rule that out. I’m pretty sure your cigarette lighter is on that same circuit. If the lighter works then it’s probably a problem with your radio.
Old 09-17-2022, 11:42 AM
Engine: 5.7 l98
thanks, i just realized above gas peddle is another fuse block. Two squeeze clips in front and two screws in back remove it. It faces up so you cannot see it it's connected to blue box.
on the 88 gta there is two fuses installed vats and acc radio. Fyi for others looking. The two other slots are empty one for power seats and another my brain refuses to remember.
Old 09-18-2022, 11:54 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
ARC radio and Vats
porters3rdgen
Car Audio
08-25-2012 04:09 PM
mantlenyy
Car Audio
05-19-2008 11:06 PM
mory
08-30-2004 04:29 PM
hurricanerugger
12-17-2002 10:27 PM
300hpse
Car Audio
06-29-2002 08:27 AM
Quick Reply: Stock radio install no power at orange
