LS alternator wiring
Hey guys I'm needing to add a resistor into my alternator wiring, I've got a 470 ohm 1/4 watt resistor. Will that one work okay or does it absolutely have to be at least 1/2 watt?? Thanks guys
COTM Editor
Received 1,938 Likes
Car: '89 Firebird
Engine: 7.0L
Re: LS alternator wiring
Which alternator?
F-body LS1 should use 10 Ohm 50 Watt resistor on the L-terminal circuit. That's not a guess, I have direct access to the engineer that has design control for the alternator. I think the Corvette alternator is made by Valeo but I don't know specs for that product.
Which alternator?
Anyways besides that, is a 1/4 watt able to be used instead of 1/2 watt??
Which alternator?
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That's why I cited my source of information because people rarely believe me.
I see I see. Well damn I guess I'll start a search for a resistor like that. I'll be the first to admit I'm not the best educated when it comes to this side of electrical
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You actually don't need a resistor at all if you switch the wire from L-terminal to the F-terminal. Just send F-terminal to a +12V switched source. This is how I wired it in my car because it's more simple and I didn't have to deal with that big lump of a resistor in the harness. (Don't make mistake of hooking to L-terminal without a resistor though).
That is valid for F-body LS1 alternator with regulator that meets OEM specs. I don't know if it's valid for truck and I didn't ask.
I don't think the F-terminal wiring is common knowledge so don't be surprised if you never see that info anywhere else.
BorgWarner engineer for the regulator. The engineering padres don't exist anymore.
I don't think the F-terminal wiring is common knowledge so don't be surprised if you never see that info anywhere else.BorgWarner engineer for the regulator. The engineering padres don't exist anymore.
Oh man I think I just answered my own question. I'm gonna grab power from another spot
No.
The Terminal one the Starter-Motor Solenoid (with the 1 Purple Wire) is NOT a Power-Source.
That Terminal receives Power when you turn the Ignition to the "Crank Position".
The Large Stud on the Starter-Motor can be temporarily used as a Power-Source...
But at that point, just use the Battery itself instead.
No.
Congrats!
Enjoy and have fun!
Enjoy and have fun!
