Which wire is Tach on HEI
Old 02-09-2022, 06:52 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
which wire is tach on HEI
My HEI has a brown plug and a white plug.. which one do i leave off to dis connect the tach for a trial run.
i just had a new tach put in the car and its got ignition problem now.
tach reads correct.
i want to unplug it and start the car.
please no tach advice.
Old 02-09-2022, 10:08 PM
TGO - 10 Year Member
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Re: Which wire is Tach on HEI
The color of the connector is irrelevant. Most V-8 models have a white wire for the tach, while V-6 models had a black wire.
The pink wire must be connected for the ignition to work...
Old 02-09-2022, 10:48 PM
Ok its the White .. actually i was refering to the plug on the connector one is brown , one is white.
good i will do it
thanks
stalkier
08-07-2015 04:49 AM
billybob6110
10-04-2010 01:44 PM
Mr355
02-08-2009 02:44 AM
91 camaro racer
04-20-2007 10:53 AM
Quick Reply: Which wire is Tach on HEI
