1988-1992 Wiper Motor and Connector
Old 06-23-2021 | 03:47 PM
vorteciroc's Avatar
Has anyone else not been able to purchase a 1988-1992 Wiper-Motor PCB or the 3-Terminal Electrical-Connector for the Motor itself?
The Delphi part-number for the Electrical-Connector Body is: 12059612.
The TPA is: 15300015, and is still highly available.
I have not been able to find these Connector-Parts for a long while now...
Has anyone found any places that these Parts are in stock?
I do find the Electrical-Connector Pig-Tail sometimes; but this is massively more expensive.
ACDelco part-number is: PT472.
Now for the PCB/ Cover, all of the part-numbers that I know of are now obsolete.
Any of you, have any luck finding any?
Old 06-23-2021 | 05:43 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1988-1992 Wiper Motor and Connector
Wrecking yard was the only place I could find those and it's been a while since I even tried to go out there and look. Still have a complete assembly around somewhere...
Old 06-23-2021 | 08:28 PM
vorteciroc's Avatar
LOL, thanks.
I figured as much.
I should have specified...
Has anyone found any Connector-Parts, Connectors, or PCB/ Covers that are "New Old Stock", reproduction, or New-New (as the Connector-Parts are still manufactured). I am assuming that the Connector-Parts are just out of stock like many other automotive parts are right now.
Old 06-24-2021 | 03:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
About 4 years ago the wipers on my '92 went away (pulse system). Here is a thread on how I repaired the board:
https://www.thirdgen.org/forums/elec...pers-92-a.html
The board was no longer available, I guess they still are unavailable.
RBob.
Old 06-24-2021 | 08:51 PM
vorteciroc's Avatar
RBob.
Thank you very much for the Thread that you created.
It took me back in time... Years ago, I would prototype PCMs for Delphi/ GM.
I started doing this as SMDs were becoming the norm... and learning to do all circuit assembly under the microscope.
I have not worked on a PCB like the Wiper-Motor PCB in a very long time.
No microscope needed!
I did not have any leaking Electrolytic Caps like you did...
But I know better than to trust the Electrolytic Caps at this age!
I had some corrosion issues, and two separate circuits lost the majority of their Traces.
I took some enameled-copper wire for speaker motors and coils...
Made jumper-wires where I needed to, and applied conformal coating after soldering.
I am going to replace the original Electrolytic Capacitors with some Tantalum Caps once I find them in similar specs.
I do not know how lucky I will be.
Thanks again!
dustierdog
08-25-2011 11:56 AM
smoothjazz
08-13-2011 07:42 PM
Kandied91z
09-17-2004 06:53 AM
sockfootball22
08-28-2004 08:24 AM
Quick Reply: 1988-1992 Wiper Motor and Connector
