Pig tail on engine harness
Old 06-29-2018, 06:52 PM
TGO - 10 Year Member
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I have a 85 iroc. Tpi engine out of a 86 iroc. The maf burn off relay connector on the 85 harness is made like one on a 87 harness I have. Except the 87 one only has 3 wire. 2 are pink and black. 1 is tan and white.
Old 06-29-2018, 07:13 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: Pig tail on engine harness
to clarify the connector is next to the ECM connectors. I will post pic's shortly
Old 06-29-2018, 07:53 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This connector? C221 and c207
https://www.thirdgen.org/forums/elec...ring-help.html
Old 06-29-2018, 08:13 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Old 06-29-2018, 08:15 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Old 06-29-2018, 08:19 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
It must be the 221. I have a spare 86 dash out of a 86 z28. No connector for a 221. Must have been a carb car it come out of.
Old 06-29-2018, 08:20 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Old 06-29-2018, 08:43 PM
Engine: Lb9
Transmission: M20
Looks like c221 here’s a picture of your harness layer out figure d
http://www.chevythunder.com/fuel%20i....%20pg%20C.htm
Old 06-29-2018, 09:01 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I looked at the under dash wiring and found there are 2 connectors that look alike. The one goes to maf burn off and the other up under the dash
Old 06-29-2018, 09:06 PM
Engine: Lb9
Transmission: M20
Are you asking about this connector ?
Old 06-29-2018, 09:24 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I thought it was that it was supposed to go to. I looked up under the dash and Sean how the 85 harness has both. So the 87 engine harness with my 86 engine and ECM/ maf sensor stuff should do the job. Thank you for your time and effort.
lugnut87
Interior Parts Wanted
04-04-2011 12:23 PM
z91bowtie1
09-24-2010 06:59 PM
z91bowtie1
09-03-2010 11:45 AM
zz28jgallo
08-11-2010 06:59 PM
bluepastu
06-19-2003 08:35 AM
Quick Reply: Pig tail on engine harness
