South Bay Fuel Injectors (help)
So I'm a little ticked..I just installed a set of yellow Bosch D3 22lb fuel injectors in my 92 l98 camaro and it acts like it doesn't have the power it should and I just got off the phone with Scott Hansen from tuned port injection services and he said that I do not have 22lb injectors because they are yellow they are 19lb injectors I'm ticked because it took me a good part of the day to put those things in...he said I need a set of 24lb injectors..well what the heck do I do now? I have maybe 5 min on these new injectors..
Re: South Bay Fuel Injectors (help)
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Now are they actually yellow or are they orange? Compare the pictures on their site if needed. If they did indeed send you the wrong ones they should take them back no problem; SouthBay has always been a stand up company on this site. If you have a stock L98 you probably need the orange ones (the 22lb).
the "yellow/orange injectors" are 19lb at FORD pressure! They are 22lb at GM pressure 43.5psi.
If you ever have a question or a concern just give us a call
516-442-4707
516-442-4707
KITT1983
04-26-2018 06:02 PM
Firechicken86
09-10-2016 12:41 AM
fasteddi
08-22-2016 05:47 AM
bigarmzz
Exterior Parts Wanted
08-21-2016 03:30 PM
