Car wont start, im stumped
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
Hi everyone, i could use a little help, i have an 85 iroc with a 92 350, i just put a holley stealth ram on and a speed density harness, the check engine light is not working(it always did before with the maf harness and tpi) and im getting no power to the fuel pump. Iv checked bulb and the fuse and all relays are new. I know that the ls1 cars need the check engine light to complete the circuit for the fuel pump to run im not sure if the thirdgens are the same as the 4th
Anything helps
Thank you
Anything helps
Thank you
Re: Car wont start, im stumped
Anything helps
Thank you
Anything helps
Thank you
Biochem
Aftermarket Product Review
11-30-2000 10:58 AM
