'87 T/A GTA Headlight Motor/Horn not working
Car: 1987 Pontiac Firebird Trans Am GTA
Engine: L98 350 TPI
I know that I'm smashing two things together here, but I figure it'll save me a bit of time in the long run. I have an '87 Firebird T/A GTA with a finicky headlight motor and a busted horn.
As far as the headlight motor is concerned, it goes up and down with no problem, however after it goes down, the motor keeps spinning for 3 to 5 seconds. Makes a terrible noise. My first thought is that the problem is either the bushings or that plastic gear that controls the raising/lowering motion. I've seen bushing and gear replacement kits, but I wasn't sure if I should try the kit first or just buckle up and buy a new motor altogether. I also wondered if it could be a problem with the relays not telling the motor to shut off, but I don't know anything about those.
Now the horn is a bit more of a problem. It's kind of important. At first I thought there was a fuse out, but I checked the fuse box and they're all in good shape. I then pried off the steering wheel cap and found that the button isn't connected to anything. That normally wouldn't be a hard fix, but there are no wires or connections anywhere that I can see, even with a flashlight. My question is basically what should I do with it? Run new wires or try and figure out where the old ones went?
Car: 88GTA
Engine: 5.7TPI
Re: '87 T/A GTA Headlight Motor/Horn not working
You need the new kit. It will solve your problem with the headlights.
http://www.top-downsolutions.com/hea...ght-repair-kit
On the horn, run a hot from the horn fuse or follow exsiting wire and reconnect it to the button on the wheel. You'll have to run the wire in the steering column.
