Power outlet help
Car: 1986 Camaro Iroc Z
Engine: 305 Carb
Transmission: Auto but T5 sitting on the bench!
Power outlet help
I want to install a power outlet to plug in my GPS unit but I am not very good with wiring and don't want to screw it up by randomly trying to tap in to the wiring. Want it only to be live when ignition on. I am assuming I can put spade tips on the power wire and plug into the fuse block somewhere and then negative to ground somewhere..........need help with the somewheres! There is no fuse on the outlet I bought. If someone has tapped into the fuse block, pic of where you plugged in would be great.
Thanks!
Thanks!
Engine: 305 Carb
Re: Power outlet help
Thanks!
Thanks!
Car: 88 IROC-Z
Engine: 5.7 TPI
Look around on the fuse block for empty slots to slide the spade into. Might be one marked IGN. Use an inline fuse holder there. Should be good to go.
Car: 88 IROC-Z
Engine: 5.7 TPI
Im guessing your cigarette lighter outlet isnt working and probably popping the acc fuse every time you plug something into it. Am I correct?
If so, why not just replace the faulty outlet for under $10 to fix that issue, and then you can plug stuff directly there, or even buy one of the many extender outlets that will plug into it to give you additional ports.
Engine: 305 Carb
Engine: 305 Carb
Nothing is wrong with the cigarette lighter, but for some reason the adapter from my GPS unit won't work plugged into it. The other reason for installing the power outlet was so I could plug the GPS unit in an inconspicuous spot, running the cord behind the console to the GPS unit suctioned below the dash pad in the center of the dash, instead of it stuck to the windshield. Turned out pretty good!
Car: 88 IROC-Z
Engine: 5.7 TPI
Engine: 305 Carb
I try to keep everything looking like it was supposed to be there, nice and clean!
GreggymacZ28
Exterior Parts for Sale
01-10-2017 08:27 PM
