Alternator Help - upgrading
Old 10-02-2015 | 10:11 AM
Buickstaged's Avatar
Car: 1984 firebird se
Axle/Gears: 373
In a 84 Bird SE 5.0. I am in the process of going from V-belt pulleys to a Serpentine system. The Serpentine system is from an early 90s k2500 pickup. All is going smoothly with the exception of the alternator wiring. So, I am updating the alternator from a 2 prong Alternator/Wire to a 4 Prong Alternator/Wire. This is probably an easy fix - however, I am clueless on this. Any and all help is much appreciated. Regards, Byron
Attached Thumbnails Alternator Help - upgrading-sam_1296.jpg   Alternator Help - upgrading-sam_1299.jpg   Alternator Help - upgrading-sam_1302.jpg
Old 10-02-2015 | 11:55 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Alternator Help - upgrading
Maybe this diagram will help. If you do a google search, you will be given a couple of choices. If you don't need the extra amperage afforded by the cs130 alternator, you can probably get by with the simple 2 wire hook-up although the remote sensing is a nice feature, especially if you have a big audio system. HTH!
Attached Thumbnails Alternator Help - upgrading-416332_1991_pontiac_grand_am_alternator_wire_diagram_1-1-.jpg
Old 10-02-2015 | 06:17 PM
Axle/Gears: 373
Thanks for the response. I do not have a big music system. Thx b
apie2546
10-16-2016 03:24 PM
Bubbajones_ya
10-25-2015 09:01 PM
bigjay89gta
10-15-2015 09:04 AM
RS Reaper
09-27-2015 08:04 PM
