Megasquirt and a 305 TBI
Hi everybody, I'm currently in the process of megasquirting my 1990 305 TBI Camaro.
The changes:
Tbi system removed
Carb installed in place
LPG/propane system installed with sequiental injection ( or semi due to megasquirt not being able to run 8 injectors)
megasquirt 2 V3
Full top end and cam rebuild.
I've read plenty of times that it's possible to run the standard ignition system with megasquirt? But Then Ive also seen that I may need to do the HEI mod Kit?
The car is almost at starting point and this is the last thing needed to wire. I was just curious if someone could put me on the right path?
I have the module in the distributor that has 2 plugs, 1st = 4 pins / 2nd= 4pins.
Will make a proper progress topic for this soon too.
The changes:
Tbi system removed
megasquirt 2 V3
