New Push Button Starter System. TGO-only discount!
Hey all. Our USA Made PBS-100 Keyless Start System is a full-feature system that will let you start your car without keys. It easily integrates with security systems to ensure that your car can't be started by some hooligan. If you don't have a security system, it can also be enabled and disabled when the doors are locked and unlocked or you can install a hidden switch somewhere to enable and disable the PBS-100.
Some of the sweet features are:
-Auto-Crank. You don't need to hold the button down while the engine cranks (you can if you want, though). Just press and release the button and the PBS-100 will read the engine's tach signal and stop cranking once the engine starts.
-Retained Accessory Power (once you turn your car off, the radio will stay on until you open your door)
-The start button's LED will dim when the headlights are turned on. See more about this nifty trick here.
-You can use a single start button, or a toggle switch and a button. (The toggle switch controls the ACC circuit)
Basically, we give you a bunch of options and features for a mighty fine price.
![](http://sanskey.com/images/kit-spread_lowres.png)
The kit comes with a 22mm Stainless Steel Start Button with Red or Blue LED (specify which one at the checkout page), three 40A relays, three relay harnesses with 12in of wire, three wiring harnesses with 3ft of wire, a fuse holder with 10A fuse, an installation manual and, of course, the PBS-100 module.
Check out http://sanskey.com to learn all you want.
Because my first car was a 92 RS, which I still drive every day, I am giving the members of TGO a $20 discount for the first 10 PBS-100's sold here. Oh, and free shipping, too.
Get your SansKey PBS-100 Keyless Start System for $140 flat.
http://sanskey.com/thirdgen_discount.html
If you have any questions, ask them. I'll answer.
Re: New Push Button Starter System. TGO-only discount!
The following was copied from here
The module is enabled (think 'disarmed') and disabled (think 'armed') by an external source. This can be anything from a security system to a hidden switch. We made the PBS-100 really flexible to be able to integrate with practically any security methods used.
True, we could use a key fob to provide independent authentication, but most people already carry around enough keys, dongles and doodads. We don't want to add more keys. We want to do everything sans keys.
We are working on a passive keyless entry system. We could whip up something real quick, but it would be the same stuff that's already out there. We like to make more useful, easier-to-use products and keep pushing the technology forward. Not just do what's already been done over and over.
I feel like a key fob that simply emits a signal to the PBS-100 would solve that. Even add key-less entry to that fob would be a nice plus as well. Hell I bet you guys could make a full security system if you wanted to.
1 Post
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
If you guys made an All-in-One security, keyless entry, and the push start system you already have (PBS-100) I would shell out for that in a heartbeat. I love the idea of adding the autostart feature to my car and the idea of just being able to unlock the door just by touching the handle.
I'm always one to think outside the box and try what hasn't been done (my HUD thread for example) and I'll be looking forward to see what you guys come out with.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
1 Post
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Is this compatible with all 3rd gens? I am not a wiring expert by no means.. how easy to install or should I just take it somewhere if I order one?
Yea our system is universal. It has been installed in a all sorts of vehicle's from 1930s hot rod, a mid 90's Porsche 911 and I think even an SUV or two. The installation steps are very similar to those of a remote starter. Take a look at the installation manual and see if it looks to be too much for you. If it is, then any shop that can install a remote starter should be able to install our system.
