shorted the injector to ground
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
I have 89 tbi car and while trying to troubleshoot it I accidently touched one of the injector wires to gnd.
quick spark and now no voltage to injector; the "other"other injector still has power. Both inj fuses are still good. Thoughts?
What did I do?
thank you
mike
What did I do?
thank you
mike
Re: shorted the injector to ground
no sir,,no check with dvm.
It was hot outside, i just looked at it.
You have provided me with enough info to realize that it HAS
to be the fuse. I was scared it was the ECM.
mike
mike
Always check fuses with a DVM!
Thanks again vetteoz
Fuse was BLOWN.
Fuse was BLOWN.
Street Lethal
04-30-2019 12:14 PM
